Background Transparency and Alpha
Hi there,
I am currently having a problem with saving a PNG with a transparent background - no matter what settings I try the png always has a background. The issue appears to solely be using orthographic camera projection, but I have done this render type previously (even on the same file as I’m having the problems!) and have never had problems before.
I am grateful for any help anyone can provide.
Graham
Did you check if your background is black in alpha channel in the VFB before saving?
thanks for your reply romullus, it was not fully black and white but having looked into it further it turns out in was the Alpha setting with the Corona Sky itself that was causing the issue
