I have interior scene, not to much complex and after starting render (no matter if it’s IR or R) few minutes later I have pop-up with:
===== Warning(33) =====
System is running low on RAM. You may experience excessive parsing times and/or crashes. You will probably have to simplify the scene.
21,5 GB of virtualized* RAM used by Corona + 3ds Max
33,9 GB of virtualized* RAM used by all running applications
31,4 GB of physical RAM installed on system
38,2 GB of virtualized* RAM provided by OS
- virtualized RAM means physical RAM + swap file on HDD/SSD
Corona RAM usage breakdown:
36,8 MB used by render elements
427,4 MB used by geometry
1,8 GB used by textures (CoronaBitmap only)
===== Error(3) =====
Bad allocation Exception!
Corona Renderer ran out of RAM an was unable to allocate memory it needs for rendering. This can be caused by rendering too big scene with not enough RAM, or an internal bug in Corona Renderer. Contact our support for more info.
Debugging details:
Wanted to allocate: 256 kB
64,9 GB of virtualized* RAM used by application
75,6 GB of virtualized* RAM used by all running applications
75,6 GB of virtualized* RAM provided by OS
Stack trace:
6 N5ᅩᄒタKH?
Jᄏ2"ンᄍ.ワ]: ■}ᄇ¥ 0x0000000000000000
5 N5ᅩᄒタKH?
4 N5ᅩᄒタKH?
3 N5ᅩᄒタKH?
2 N5ᅩᄒタKH?
1 N5ᅩᄒタKH?
0 N5ᅩᄒタKH?
After recieving this message 3ds max instantly shuts down, so I don’t even have Minidump File saved. Crash happens when the view has 5-7% noise level.
The scene has only 250 MB!
My PC:
- Intel(R) Xeon(R) CPU E5-2673 v4 @ 2.30GHz / 20 Cores, 40 Threads, Turbo Speed: 3.3 GHz
- 2x Graphic Cards Nvidia GeForce 1080 ti (11 VRAM each)
- 32,0 GB RAM
- Windows 10 Pro
Can anyone help with this issue?
