bad buckets on certain materials
Hi
This is a problem that I have been dealing with since SP3 and never got an answer:
please look at the image:
I use a simple VRay material for the windows elements and get some buckets rendering with different tones - Note that there is no map used in this material - just plain material.
reflection is set to about 10 but other than thta - nothing
I had thgis problem even with WARD and Phong in the BRDF.
As you can see the other area were rendered OK.
BTW - I only noticed this in a Birdseye view render and not in the view taken form a human eye level…
NIR
It should work if you disable the interpolation option. This issue is fixed in SP4.
thx but where exactly is this parameter ?
Is it in the material GUI or Vray’s GUI ?
EDIT: This was done in SP4
Nir
It is right below the reflection subdivs parameter in VRayMtl (it’s labeled “Use interpolation”).
So should I use it in all of my materials ?
I ask because I always use interpolation (as it quickens rendering)
ALso - Are u saying that in SP4 the interpolation can be used as before ?
NIR
This particular problem is fixed in SP4, yes. However it might be better to wait a little until we release SP4a before upgrading.
now that SP4a is released - was it solved ?
I am hesitating to install SP4a.
Regards
Nir
