Krita would be a solution as I assume you go back to Nuke after Photoshop? and Photoshop is there just for some paintovers?
it has ocio v2 support (view lut only, cant bake the transforms) and icc profiles are working ok with floating point images.
it reads multichanel exrs although not multipart exrs. might be a deal breaker.
Photoshop is using 32bit psd file for any float data, full and half.
If you use half float for your display transformed output exr are you sure you have enough color information there? midtonnes to highlights this is like 10bit file precision. might be enough for what you need I guess
if I do Photoshop with float color I just use big csp luts that account for “srgb view lut” in photoshop. I get 1:1 when compared with proper ocio transforms.
The files will be further processed in after effects after matte paint.10bit should be enough for our use case but we need the initial Color range to have the flexibility before going further down the pipeline reducing the documents Color depth.what are cps luts? I was thinking that it might be possible to create a lut layer to match the colors as a first step in photoshop.
i will look into ocio and icc profiles,just want to make the workflow for matte paint as simple as possible,
I have no experience creating more custom icc profiles but from discussion at ACES Central I remember one of the mentioned workflows was getting 16 bit integer log encoded files (acescc or acescct I guess) for matte painting to PS with icc profile as ACES display transform. Not sure how much matte painters like painting in log (I don’t think PS color picker is color managed)
csp luts are the only lut types working in PS that can access floating point range of colors. 1D prelut is max 4096 points + size 65 3D cube. it is enough to perfectly encode ACEScg into ARRI LogC4 (range -0.018… to ~470 float, ACEScc log is maxed at ~222 float at 1.0).
attached: lut - aces 1.3 acescg to aces srgb display with reference gamut compression + reversed srgb transfer function to get rid of Photoshops view lut: https://youtu.be/6zbHbYmhDvQ
Man, thanks for the detailed info.i will pass it on to our TDs hoping they cane make sense of it really appreciate this.i will update what we will end up with.
have a nice evening
issue with baking ACES ocio transform from VRay is that you need custom ocio config to get ACES 1.3 version of the transform (one with Look: Reference gamut compression) as ocio looks are not supported by VRay’s frame buffer.
The csp is looking very promising i still have a slight color shift (too much red) in my image, i guess because i use slightly different settings in maya vray
i am failing in creating a csp in nuke for my purpose:
load the ocio config we use in maya into nukes custom ocio field.
create a CMS Test pattern add a OCIODisplay node,
set the values like i have in the VFB and add a node GenerateLUT writing a .csp file, logaithmic with 1D preLUT size 4096.
I have no idea how Nuke generates luts. I make my csp luts with a simple spreadsheet (1D) and just add 3D cube generated from Fusion.
if there is exposure difference this might be related to VRay output. VRayUnclampedColor element in 3dsMax for example does not contain VRay’s exposure adjustment (camera or other).
i checked AcesCentral and there is a nuke file alexfry · GitHub - i was super naive as the process to create your own lut is way more complex inside nuke.
Finally I ended up using these two files (from Alex Fry):
