bake to texture
corona render does not respond to the cage parameter in bake to texture
because of this bake to texture is not possible with corona render!
I found a small solution to this problem when baking from LP to HP
on the LP model I split polygons by uvw and throw the push modifier
goes imitation cage and baked normally.
I hope the developers will fix this
