Hi!
I was wondering if it is possible to bake the vray toon outline into texture?
I tried but without success…maybe I´m missing something?
thanks
Mathias
Hi!
thanks
Mathias
You cannot bake the outlines from the VRayToon since it’s a view-dependent effect rather than a shader. Maybe you could share some information about your desired result, so we can possibly provide another solution?
Thanks for the reply. It makes sense.I had hoped that some Outlines might show up that are not camera angle dependent (geo intersections).
Unfortunately the asset i´m working on will be used in a different application/render engine later on.I guess using a dirt shader might give me a similar result if i use a very tight angle.
