I have a very large scene (not so much in poly count but more ‘physically’ large).
I’m doing a lot of bake-to-texture.
When I bake a texture with a decal on it, the Corona Decals generally render very blurred.
That is, I think, unless the camera/viewport (when pressing the bake button) is close to the decals being rendered in the texture bake.
So if I want to process many bake-to-texture renders at once, only 1 will not have blurry decals. I have to do them one-by-one, ensuring the camera is close to the objects I’m baking.
This sounds like filtering blurring. Check if it’s not set too high. For baking you probably would want to set it to lowest possible value, or maybe even turn off filtering completely.
May i ask you how you are baking to texture with Corona? I tried to bake simple plane with a decal on it, but the thing is completely broken. On first try the baked came out as some garbage and on the second try i disabled displacement and Corona stuck on geometry parsing, gradually increasing RAM consumption until it run out of memory. Like baking was never perfect with Corona, but now it completely useless. I’m using Max 2026 and latest Corona daily.
I’m using the bake-to-texture feature. I do have to disable displacement, otherwise it works just fine for me… Other than this decal/bitmap issue I’m having.
Of course I first do an unwrap (auto unwwrap as I’m lazy).
My business has evolved a bit recently which has meant I’m using bake-to-texture more than anything else lately.
