# Baking with Flatiron
**URL:** <https://forums.chaos.com/t/baking-with-flatiron/63559>\
**Category:** Off-topic\
**Created:** [April 23, 2017, 7:51am UTC](https://forums.chaos.com/t/baking-with-flatiron/63559 "2017-04-23T07:51:14Z")\
**Posts on this page:** 1\
**Showing post:** 13
<div class="post-metadata">
**Author:** ![mitviz](https://dub1.discourse-cdn.com/chaosprd/user_avatar/forums.chaos.com/mitviz/32/47310_2.png) [@mitviz](https://forums.chaos.com/u/mitviz)\
**Post date:** [April 24, 2017, 3:44pm UTC](https://forums.chaos.com/t/baking-with-flatiron/63559/13 "2017-04-24T15:44:58Z")
</div>
> [@Wave force WIP](https://forums.chaos.com/t/wave-force-wip/54908/3):
> How many elements? I’ve done up to around 200 - and can get through the process within a day for rendering. Using scripts you just might want to process in chunks since the software will hang. Baking of course takes additional time… helps to do a test run at a lower baking resolution to catch any issues. If you go this route, reach out via the website if you want to discuss things further and I can pass along the scripts I use.
less than 200 elements for sure alot less, maybe 40 or so, would love to do it via flatiron is possible since i dont want to spend time on it, if this gamma issue was not a problem i think its ok, i ran some tests and it seemed fine minus the gama issue. didnt have any slowdowns really and render was fast since its not some overly realistic scene
_[View the full topic](https://forums.chaos.com/t/baking-with-flatiron/63559)._
