Another R&D job done in few hour searching for inspiration.
1 hour render at 1080, PT+HD cache.
Like it
really nice, can you give more technical info on lighting set-up and am i right to assume that this is not a raw render?
Hi there thanks for your comment, about the light I just used an HDRI map in corona enviroment.
The settings in Corona are all default settings.
I just start with a plan a car and than I decided to add some baloons done in CLO3D.
Tha grass is Corona scatter.
The post is part in AE where some time is easier achieve some good color correction and than photoshop to paint some fake light and a little bit of blur on top, plus the BG that has been replaced.
Nothing particular in this process, the composition of course is not great, the bush (that i dont like) are done with some tree under the terrain level.
That’s it.
Very good work! I like it!
Very nice! Will there be any animation?
It is a good idea, I will try at 720 I am not sure if is achivable with one machine.
Probably I have to use PT+PT.
nice job
I like the bush right there. For one its a good stopping for the car and the way the light is passing through the leaves just gives the viewer a strong sense of where the light is coming from.
