Well, admittedly I haven’t had enough time to fully explore this, but as I imagine it it would be much cleaner.
first of all you don’t need to build, increase render settings for, and potentially hide another piece of geometry.
secondly, I see barn doors as a very precise cutting tool, much like max’s hotspot/falloff, but having direct angles of control straight from the light source…I’m a transplant into 3d from theatre, and this technology onstage is great for putting light just where you want it…
lastly- and this is out of my knowledge base, but I imagine efficiencies within the rendering calculation that might be created from the more precise nature of built-in ‘hinges’ right off of the vray light. The renderer could exclude all calculations except those coming at whatever angles the shutters dictate…
It’d be enough to be able to texture the vraylight plane.
That’d take care of the barn doors with a gradient, but also allow for proper Gobos to be put on the lights.
Here’s a rough version of what I have in mind…The blue panels are the shutters, and the yellow and pink fill the gaps from changing the angles. I’m not certain you could get the same thing from a gradient map~
