Would it be possible to get ‘built in’ barn doors? Directly in the light parameters(like in Maya). It would give you much more control over your light.
Hi, I had to google to find out what it is. ![]()
Do you have any practical use for this?
In Corona you could play with the directionality parameter, change light shape, and/or use a custom texture for the light. Using a procedural texture should give you a lot of flexibility.
Another idea is to model the “shutters” manually. ![]()
Correct me if i’m wrong, but i think directionality in CoronaLights does exactly the same thing that barn doors on softboxes does. Only that Corona ones are infinitely long.
Oh, i overlooked “like in Maya” part :] I was refering to real world barn doors modifiers.
Yes, no actual I wasn’t precise with that. What I strongly prefer to the Maya-thing is a viewport-representation of the barndoors. It’ more haptic.
Then in Corona you can’t do it with a disc light using directionality only.
If symmetric: yes. But I need the barndoors when I want to ‘limit’ a light or in other words: need 2 directionality attributes in the light instead of one.
It’s also great to create ramps on the lit objects
Yes, I actually did that, but the drawback is: these helpers have the nasty habit of getting render/attributes they shouldn’t have and showing up in the render. Especially if you’re passing the scene over to another artist. ![]()
I’ll try to post some examples later on…
thanks for your contribution
