Basic sampling test of bright reflections in distance
Hi there.
Curious about fireflies I made the test attached.
Is there a solution for the sampling of bright reflections in the distance?
It seems that vray assigns 1 white pixel no matter how far the reflection is. Is this correct?
Thanks.
Using sub-pixel mapping with clamp might be a solution… another idea that I’ve been toying with is to force the glossiness of the material to be such that the size of a highlight is never smaller than a pixel - in that case, the highlight just gets dimmer and easier to sample. But this is not in any build yet, just experiments.
I stopped using this after getting strange exposure on the overall rendering. So I always try to avoid those two.
After posting the question, I thought that it may just be a natural thing. Because the light source is so far away and so strong (sun), the reflection is always the same, no?
Please, see below the reflection of the sun in water.
The difference may be in the DOF? :face_with_spiral_eyes:
This is correct, yes.
The difference may be in the DOF? :face_with_spiral_eyes:The DOF will make the highlights blurrier, yes. But they would still be difficult to sample.
Got it. Thanks!
Yes. I tested a similar scene with corona and vray does a much better job.
So y’all are using min 1 max 100 with MSR 6? any Filter? I have these issues often and have yet to find away to solve them, especially jaggy edges in general in overbright areas. That’s why I mostly end up using SPM and clamp…
