Hey all,
I’m playing around with a very basic smoke sim, that follow a spline, i can get it to work fine but when i add cutter geom it fails to follow the path and just smokes around the top of the emitter…
the cutter is just a sweep on a copy of the path that has been shelled and collapsed to form a pipe…
any help is greatly appreciated.
Thanks.
Hey,
Do you want the cutter to interact with the simulation or you want to use it just for the rendering ?
If you need it only for the rendering you can right-click over it and from the Phoenix properties set it to Non-solid or exclude it from the sim from the Scene interaction rollout.
I just want to restrict the smoke to be inside the pipe…
it works without the cutter geom but when I enable it in the rendering rollout the smoke doesn’t follow the path…
I really appreciate any help!
Hey,
When you right click on your cutter geometry, is the Solid option unchecked? If it’s not, it would be an obstacle to the fluid simulation - please uncheck the Solid checkbox
Cheers!
Hey mate,
I tried it (unchecking solid object) but it doesn’t “force” the smoke to stay within the piping… it behaves like its (the cutter geom) not there at all…?
Ah yes - the render cutter just ignores parts of the fluid at render time.
Sounds like you might be trying to add an obstacle to the simulation after all though, do I understand you correctly?
Can you show some screenshots of your setup, so we can be on the same page?
Ah - if you want the pipe to collide with the smoke you will need to have the solid checkbox turned on.
Then in order to get proper collision with the smoke - make sure that the pipe has some thickness (at least 2-3 voxels) and your grid resolution is high enough.
Then if it is still not working correctly - try to invert the normals of the pipe.
Cheers!
Did you try my suggestions from above? Inverting the normals for the pipe should be the way to go.
yeah mate i did and nothing happens at all, ie. it doesn’t generate any smoke…?
Can you attach the scene so we can take a look? It needs to be zipped in order to work with the forum attachment system.
Thanks!
Hey Georgi,
here you go mate…
Thanks.
Smoke_test_03.zip (884 KB)
Hey,
I just took a look of your scene and I’ve noticed that the spline called “shape_cutter” is a Solid Object and it is stopping the smoke to reach the following path.
If you uncheck the Solid Object checkbox for the “shape_cutter” spline, the smoke should start following the path.
Hope that helps!
thank you mate, I appreciate the help…
so anything can get in the way, even if just a spline and not selected to interact with the sim…?
Everything interacts with the sim by default - if you want to leave something out, you can exclude it from the Scene Interaction rollout
Thank you so much, you’ve (all) been a wonderful help!
Hey, some more news - since tomorrow’s Phoenix 4 3ds Max nightlies, splines will not interact with the simulation unless you explicitly extrude them
