I was just wondering if there is a good workflow for batch rendering still images from different camera angles into 32 bit multi-layer .exr files that include all the various render elements in them for later compositing.
Seems like if I try batch rendering into .exr files, they always come out very distorted and the only way I can get the proper multi-layer exr file is by saving it out from the VFB or by using the Render Setup > V-Ray > Frame buffer > ‘V-Ray raw image file’ save option in the render settings. These are the only two ways I’ve been able to generate the multi-layer .exr files that I can composite the final image from.
Is there a way to get these .exr files to output from a batch render?
Thanks!
