Batch Render and Vray 6
Hi
I set Batch render off to render out views.
Can’t stop it once it starts, and it dosent save the channels.
The not being able to stop it is rediculas…is this a bug…
Hi
Hi could you give us a bit more details. You are using 3ds max’s batch render and how do you save your output? Which dialog are you using?
Vlad Thank you for answerreing.
I am using the max vbersion built in to the Max Menus..Rendering…Batch render.
Is this not used any more I can see save all channels on the VBF, which is great, but I was hoping the click and go.
Aslo The nerw hot fix 2 relaased the other day, the clouds won’t work for me.
Max 2023, no fixes added to it yet.
Thank you again.
Phil
Vlad sorry cloulds working I just had to reset the sky component.
Thank you
HI you have to disable the V-Ray Frame Buffer, setup your output through the batch dialog, setup your render elements in the V-Ray RE list and that’s it. The scene will use 3ds max’s frame buffer instead and save the render elements.
Vlad , Thank you again.
I presume it is time start learning again…
Vladimir, I tried the method you mentioned above but it doesn’t seem to work with VrayDenoiser. I just get a file that’s all black. Am I doing something wrong?
The VrayDenoiser needs VFB in order to work. You can use the Standalone Denoiser Tool as an alternative.
Actually this will not work straight away since the V-Ray Standalone Denoise still needs render elements to operate.
So currently there’s no way to render a denoiser element in batch render, right?
Bump. Is this still true? I’m having issues with batch render ignoring my cryptomatte filter on my denoise layer. Its denoising the whole image instead.
Not sure. I switched from Vray to FStorm about a year ago.
