Is this a known issue or am I not doing something correctly? When I batch render the view renders without the section on, if I render on its own it renders correctly.
I should mention that the scene before this has a section on and it does render correctly.
Could you please make sure that the section cuts are enabled for each specific scene? Note that V-Ray respects the state of the section plane/s for individual scenes. You can monitor the state through the V-Ray Asset Editor > Geometry tab as you cycle through the scenes.
Additionally, please be informed that you would have to create new section planes for each scene if a different position is required.
Confirmed that the sections are setup correctly. They do no render enabled with batch rendering.
Could you share the project with us so we can investigate in detail? If this is alright, send us an archived copy (Extensions > V-Ray > Pack Project) via email or a file-sharing service of your choice to support@chaosgroup,com
Reference this forum thread as well, please!
