Batch render, different dome lights
there are 3 scenes with different dome lights. How can I make a batch render using each dome light for each scene?
thanks,
Lorenzo
You can hide dome light you are not using and uptade the scene.. You should activate use transform option to rotate the dome using the same hdr..
better yet: assign to layers and use your scene states (layer1 off for scene1, etc) to control visibility scene to scene
thanks, I will try that.!
Mmh It seems that vray doesn?t switch on the second dome light automatically. So when the first dome light is on, it stays on for all the scenes…
make sure they are all “on” and just hidden via layers (also make sure your normal sun is “off”). Also make sure your rendering settings include an unchecked “render hidden lights”
Many thanks! You saved my weekend :slight_smile:
