Batch Render Issues Enscape 2.7
I have a set of views created from Revit 2019 from Enscape 2.6. Whilst using this version of Enscape, I would hit batch render and the views would all come out correctly. Since updating to Enscape 2.7, the views render with missing walls and different parts from the Revit option set. Is anyone else having this issue?
I’m sorry to hear about that - it’s probably trivial but please make sure you’re running our latest release, in case you’ve been using a preview so far.
Furthermore, if that doesn’t help, please kindly send in a feedback report as described here. If possible it would be ideal if we could receive a project, alongside some screenshots showing that issue, or at least part of it in which we can reproduce this problem. Thank you in advance!
I’m also having issue with batch rendering in 2.7.
it gets stuck, wrong views. everything is a mess :confused:
I’m sorry to hear about that - if it gets stuck frequently, please send in a feedback report so that we can troubleshoot the cause behind this.
Regarding the other problems, can you maybe specify these a bit more? Perhaps you have different settings tied to the views which make them different in the end renderings?
