Perhaps I’m dumb, but I really don’t find the Vantage animation system intuitive. I’m trying to Batch Render multiple animation sequences from several imported 3DS Max Cameras. Firstly - it would seem you have to specify the camera you want in the Still Image tab in order to select the camera in the Sequences Tab (which only shows the scene state). Shouldn’t the camera drop-down be in both tabs? I can render out the first sequence OK if the camera is specified as current in Scene Animation in the Animation Editor. The second Batch sequence will render one frame of the second camera, and then revert back whatever the Scene Animation Camera is current. Why? How do I get the second Batch sequence to render all frames from a different camera?
The docs say this:
If you select a Recorded Camera (an animated camera view captured with the Record Camera Movement button) from the dropdown in the Render setup window > Still image tab, only the first frame will be rendered.
In order to render the whole sequence of the recorded camera, you have to first add it to the camera track of the Animation Editor and then use the Render setup window > Sequence tab.
…I don’t get how this works. Are you supposed to drag multiple camera icons into the “Empty Camera Animation” track?
I think the answer is the same as here: Exporting animated camera from 3dsmax to Vantage - Vantage :: General - Chaos Forum
I’m not sure if there is another way to batch render different sequences, because we have a single animation timeline. Unfortunately the product managers who can better answer your workflow/UX concerns are on vacation this week.
What I want to do is Batch render imported cameras (with animation) - each with a different frame naming, and a different scene state for each one (ie Sun position, exposure etc.) I thought I had finally understood what to do in my test scene, by dropping the cameras in sequence in the Animation editor, and specifying frame ranges/scene state in each Batch sequence. Unfortunately Vantage crashes every time I try this. I’m guessing Vantage just does not like imported cameras with an animation path. Perhaps my only option is to set up camera movements in Vantage. It shouldn’t be this hard.
