Batch Render Stereo Images w/ Corona Camera Modifier Problem
Anyone have any luck using the native 3ds batch render using physical cameras with Corona Camera Modifiers applied? Specifically stereoscopic images. Batch render seems to ignore the modifier altogether.
Thanks.
I have just tried batch rendering with Max 2018 and Corona 1.6 hotfix 1 (both from 3ds Max ui, and using a bat file) and it seems to work fine. Can you explain what exactly you are doing, and what is happening?
