hi, I am using batch render for the first time; i installed a script - batch camera render in 3dsmax.
in batch mode how can I assign the relative VFB saved in .vfbl format to each vray cam?
I also tried, after saving the image, to open 3dsmax, open VFB and the image and apply the .vfbl file but it is not the same image.
Is there a method to assign the .vfbl file to each image?
Thank you
Matteo
ps..
for each vray cam I have a different .vfbl
There isn’t an integrated way of doing this. Probably it is possible to achieve this through a post-render script for each scene (and camera I guess), however, it would be a complex one.
Which image is not “the same” - the one with or without the color corrections? Could you provide an example scene/ screencaps of this happening?
There seems to be a drastic color difference between the RGB and the VRayDenoiser channel, which shouldn’t be there. Which V-Ray build do you have installed? Which denoiser engine are you using? Have you made modifications through the VRayLightMix? Is the difference present without using batch rendering? Could you send the scene so we can take a look? Mention me and include a link to this thread.
