I use sketch-up 2021 PRO, every time I set up the camera & do batch render, I get a wider angle & the view is distorted, it’s really annoying o do 30 Screen shot when you have 6-10 models to render with 30 view each,
there’s a bug in the software & Enscape ignores it & it is a problem. FIX IT
@HazemZ , thanks a lot for your report and welcome to our Forum.
In the very first instance, make sure that you do not have “Synchronize Views” enabled since that influences the field of view which is used for the live Enscape output, which is not taken into account when batch rendering. Please also make sure that you’re definitely running our latest release of Enscape.
While this should not be the case here, please be aware that you can also link Settings Presets to any of your views which will then be taken into account when batch rendering - overall though if no settings are linked and synchronize views is turned off, you should get basically the same output in both Enscape live and the final renderings (given that the aspect ratio is about the same).
