batch render with interactive light elements
Hi all!!
I have a problem with batch rendering.
I want to render 2 image of same project with .cxr format. I want the first image with an hdri, second with a corona sky. It seems very easy, but unfortunately I couldn’t manage to do it. So far I have achieved to receive 2 cxr. format output, but none of them have the interactive light elements. Somehow batch render erases them…
I would be really appreciate if anyone give it a try…
thank you already…
I can confirm this, the batch render deletes light objects from the LightSelect render elements (it will leave the Include Environment checked or not, though). I was using Max 2018 in this case (as Max 2017 has borked its UI and won’t show the Scene States dialog), and the Aug 9th daily build.
  • Create simple scene, one CoronaLight, CoronaBitmap with HDRI as Max Environment
  • Set up LightMix, and two LightSelect layers (one with the CoronaLight, one with nothing in it but Include Environment checked)
  • Saved the Scene State with everything selected as components to save
  • Changed the CoronaBitmap to CoronaSky for the Max Enviro
  • Saved a new Scene State with everything selected as components to save
  • On Batch rendering, I get the two Environment LighSelect cxrs showing correctly (one lit by the Sky, one by the HDRI). I also get the CoronaLight LightSelect files, but both are black. I get both LightMix cxr files, which correctly show illumination from both CoronaLight and Environment, but the cxr has no LightMix ability in the CIE.
  • On checking Render Elements after Batch Rendering, the LightMix with the CoronaLight now shows where it used to show the CoronaLight
Is there any solution for this problem? i just recently encoutered this and its really frustrating :frowning:
Sorry, but we don’t have any new findings yet. We will look into this ASAP.
This has been fixed in V3. Definitely not an issue in the latest Dailies.
Hi
I upgraded to corona 3.0 yesterday because all the lights in my render elements were being erased in the dialog and tried to batch render a scene- I removed all the routes from each render element and I’m still getting everything erased. Also created a new render preset with corona 3.0 before trying to batch render. I’m using 3dsmax 2016
Am I missing something else?
thanks
Can you explain what exactly you did and what exactly happened, so that we can try reproducing it?
