Batch render with vray multiple objects with different materials using the objects name and material in the saved file image name.
Can any help with suggestions, workflows or scripts to batch render from 3dsmax using ideally backburner multiple configurations of different objects with different materials using the objects name and material / configuration in the rendered image file name.
I have around 40 different objects and seven different materials and would like to batch render these to image files using the object and the material name avoiding the need to do this manually.
Take a look at Reindeer.
I believe this is what you need.
https://animathings.com/item/reindeer-2018-license
Thanks JezUK I have requested a demo and will give some feedback on the plugin.
