when will be implemented the Batch Render (multiple animation cameras in 3ds max) ?
Hi poliedrostudiosrl_poliedrostudiosrl,
That it is in the TO DO list but cannot say when i will be implemented. As a sort of a workaround if you use a .vrscene you can drop the imported cameras in the camera track (without interpolation between them) and render out the entire sequence: https://drive.google.com/file/d/1exo…usp=share_link . However this will not work if you use ‘Render animation with Chaos Vantage’ workflow.
Alexander
Thank you,
but the method doesn’t work when during an animation there are sequences with overlapping cameras and frames.
