batch rendering bug
Hi
I would like to solve the following issue with 3dsmax render presets if someone can help me
I first prepare the render scene settings with a lightmix cshading and I include the light sources. Then I save the render presets and when I load it again the light mix cshading has the selected lights sources deleted for some reason.
Can someone tell me if I m doing something wrong or if it s a bug?
Thanks a lot, would help me a lot to solve this issue!
Matej
Same here.
Save Preset > Test
Load Preset > Test
All LightSelect’s are empty. Its probably due the fact that this kind of “save” does not carry such settings.
If you really need those settings I can help you come with workaround.
