Batch rendering camera view angle way wider than viewport
not sure if I’m missing something but this looks wrong
In the past there was a bug that the lens length of the first rendered view was used for all following shots during batch rendering.
BUG - Rhino views using wrong lens length for batch output
But I suppose so the bug is fixed in the last two years and you run in an other. Is it still alive?
To me this looks like the rendering was created in orthographic view.. isn’t it?
Dear Enscape,
I’m running into the same problem!
With single renders this is not an issue. But with batch render the camera setting does not sync with Rhino.
I agree with the others. this bug was fixed recently. Now with version 2.7 is back?
Enscape build: 27-02-2020
Rhino version 6. SR 23
This should very well be resolved in our latest preview - can you try it out and let me know if you still experience this issue afterward?
Dear Demian,
The camera settings are still not in sync. See attachments.
In the meanwhile I’ve downgraded my Rhino version to SR 13 due to other issues.
I hope this would not influence the outcome?
Erik
@MrShifty515 , a resolution for this should be implemented with our next upcoming update 2.7.1 - thank you for giving the preview a try. Also, are any of the other issues related to Enscape, or Rhino only?
@Demian Gutberlet, I use now this version: Enscape-2.7.1+20192 from 18-03-2020.
Within this version the mismatch with the camera settings are still present. Please fix this issue.
I’m having issues the with batch render view not matching the sketchup saved scene
I’m using Enscape 2.8.0+26218
The Batch Render used to be a life saver. Now, Im having to rendering each scene and takes forver. ( There times the Enscape will crash after exporting 3 scenes)
Please help!!
Also - Not sure if this is the right thread to make requests.
Few things
  • Is there a way to to render grass on walls.
  • Is there a way to create flames / fire ?
Sorry - I just realised i came under the Rhino application thread
Sent you a reply in the other thread you sent a message. And, welcome to our forum!
