Batch rendering interrupts with save confirmation
When batch rendering two or more scenes, the confirmation to save the Rhino scene is displayed and the batch is interrupted.
Is there a solution?
Confirm with Rhino5 + V-RayRhino, version 3.60.02 adv
Bump!
Nobody is here?
Hello, and apologies for the delayed response!
We were not able to reproduce the issue on our end. Could you please confirm whether you’re using the latest Rhino 5 version (service release 14)? A screenshot of the Rhino Options > Files window (Files options | Rhino 3-D modeling) would also be appreciated.
Kind regards,
Peter
It seems that it is a problem peculiar to Rhino Japanese version. [tested on Rhino 5 SR14 Japanese]
In Rhoino Japanese version, the command “-_Open” determines the input value “No” as an unknown command.
It is necessary to modify the Batch Render command which does not depend on the localized version.
Thank you for the additional info, we already have a solution devised for this particular issue. It will be included in v3.60.03 which is expected to be released soon.
Kind regards,
Peter
Thank you for information.
We are waiting for a fix update.
