I’ve got multiple vray cameras set up with different resolution overrides - with that I’m also rendering out render elements.
I use the batch render tool to create the various views:
By checking the Override preset button and giving each camera a different frame, it prevents the render elements to be overridden.
Problem is that the camera resolution is also overridden - I suppose I have to manually type in the different camera resolutions for each view as well?
It seems very tedious? Or is there a simpler/quicker way?
