Batch rendering with all Passes exported
Hi
I am sorry if this has been covered, but I did look and could not find the topic.
I want to render out a number of views, and the usual 200-300 passes, and then also export render elements also so I can do post work in photoshop.
In Vray I would go to Frame buffer and set it up there.
So whats the equivalent in Corona.
Thank you
philip
nobody?
Everything you need you find in the “Render setup dialog” (F10)
And combine this with Backburner.
edit:
could me of great help for you
Belly
Good Morning.
Thank you.
Very much appreciated.
Philip
