Batch Video Render
Enscape Please support to batch video render, for multiple video path at once click to export
Hey @mm3d.arsitektur , this is already filed as a feature request on our agenda. Your voice just added a further upvote to the topic. :slight_smile: Thank you for the feedback.
okey, hope this realized soon…
Agree. This would a good feature.
Current ‘workaround’ is setting up multiple paths in one go with zero seconds between them. Then render the whole and edit out the jumps from one path to another.
@annevanzwol Combine you the paths per xml file? Are the paths not smooth interpolated at the ends?
haven’t tried editing the xml file. Just use the enscape editor and setup different camerapositions for the different paths and make the time between paths 0 seconds.
Interesting trick. Little disadvantage could be that the ends of the paths are bend to the next path or?
yep. Just edit them out
In many cases we need different settings for each path, so the workaround presented here would not be useable.
(Very much appreciate the tip though!)
We really need a way to save model states and render settings per view or path, and a way to render them in sequence.
Yes a batch video render would be awesome!
Thank you all, added upvotes for this feature for @annevanzwol , @renderwiz and @jtubb
Can I add an upvote for this too please? Would be very helpful!
@Kaj_Burival_1 hope this can provided in version 2.7
Please add this feature.
We currently are rendering multiple paths of the same area with slight differences so we can use a video edited to fade between multiple options. This current project I’m working on has 5 options. This would allow us to send all of those walkthroughs over night instead of babysitting a computer waiting for it to finish to send the next option.
@kalbrau , @mm3d.arsitektur , @Vincent_2 , forwarded your upvotes thanks. No ETA regarding when this will be implemented though I’m afraid.
Was already typing up a new thread, but then I found this.
Upvote from me too please.
This would really improve my workflow!
Happily forwarded your vote of course, thank you!
Upvote from me also please!
@JohnB_1 We’ve recorded your upvote :thumbup:
Is there a way to prioritize this feature in your schedule?
I mean it’s been 2 years and a half and we’re still voting…
Thank you!
