Bathroom with sloping ceiling
So far my best bathroom render straight from Vantage (only sharpened in post process).
Well done!
Excellent work.
I do a lot of bathrooms but I’ve been stuck with V-Ray for Sketchup.
I didn’t dare to take the step to Vantage but when I see the result it really makes me want to try.
Is it possible to share the scene to study it and learn the settings?
Sweat! Very encouraging.
Hi, I jump to vantage alost instantly when I had right hardware. I needed to regret some functions (vray fur, procedural maps for bump) but my workflow speed up significantly.
Those images was rendered under 2 minutes each /RTX3070/- via live link. I can send you .vrscene and .vantage file, but there are only few things to be set in vantage:
1. Most important is to chech the recently added filmic tonemapping in post tab (that is huuuuge enhancement for my workflow).
2. Reduced bump multiplier and bloom settings.
3. Using warm light color and adjusting camera white balance.
Scene is ighted with 6 vray spotlights - warm white, domelight with sky texture and few rect.lights for LED strips.
Thank you for your answer.
It would be great if you could send me the .vrscene and .vantage files
Thank you again.
