when we run a network rendering with BB, the renders on all my nodes start at 1:32 resolution
I would call this a feature - you get lower CPU overhead for the framebuffer you are not using anyway ![]()
This is because I try to create VFB small enough to fit into 3dmax window. When there is no 3dsmax window, I try to fit it into an empty space, hence it zooms out as much as possible.
Ahh, ok. Maybe give us an option? Cause, we use a second monitor to see if BB works fine. And, every time, we have to zoom from 1:32 to 1:2 or 1:1 =)
I slightly changed the way it works. It will still pop a small window (width of the toolbar), but now the content will be zoomed to fit the window, not 1:32
I think this is better!
