Some View please give C&C.
well done in max and rendered using Vray.
My first post on this forum
Nice render…
Best regards…
thanks Stilgarna
Nice renderings! I would probably put the woman behind the curtains, she looks a little 3d.
Nice renders, but i can see some minor problems that u can solve easely, in the first image u have problems in some cornes with “white light”, u can soften the hard edges also and i would change de floor map.I hope that can help.
And welcome to the forum.
Onz
Thanks alot
need some aa on that last render, but im guessing you know that.
Thanks for the comments
hi guy please keep giving me some more C&C
OK then:
1st image - the yellow light behind the camera can be switched off. Add a vrayplane light shining in from those doors. or just move this yellow light behind the camera to be by the doors.
2nd image - is there a wall light outside there or is the moon a bit overbright?
3rd image - same as for image1. …and your sunlight coming in from outside should be sharper.
General. Interior lights are never that bright as in image1 and 3 when you have sunlight coming in from the outside. except if your table lamp is a stadium light
Those are the 1st things I would have looked at. Some of the veterans here can probably give you some other tips such as to get rid of the splotches and to get a cleaner image
Kind Regards,
Morne
thanks alot
