Hi all. Wondering if anyone has any benchmark scores for the base Apple M4 which at the moment is the 10-Core CPU / 10-Core GPU / 16Gb Ram?
Just seen I can get one for £533, was considering using it as a render node. But only if it’s worthwhile…
Probably incredably good benchmarks for 500 pounds but 16Gb will be the bottleneck slowing things down a lot depending on your scenes. I was thinking to get a M4 Mini pro but it’s max. 64Gb.
I usually need 128Gb with the amount of vegetation I like to render on my M1.
I would not be surprised if the 10 core M4 renders at about the same speed as any other 10 core M-processor. The core count seems more important than M1 or M4. The M4 has only 4 performance cores though and 6 efficiency cores at lower speed. The M4 pro has 10 performance cores and better cooling.
