Bercon 3.0.4 Envfog buckets
Strange results and incorrect render buckets (not DR) with Bercon noise (3.0.4)
nb. updated to 3.0.4 but note the map windows only shows 3.0.1
We’re looking into it now. We made a change to the Bercon maps that probably fixes this and other issues, but I just need to confirm it.
I’m also getting problems with the bercon fractal noise not scaling (which I thought Vlado fixed in 3.04)
Can someone confirm that Bercon 3.04 displays as 3.01 in Max or has my plugin just not updated correctly?
Thanks Vlado, please let me know if you have a fix.
Vlado did you confirm the changes you did fixed the Bercon noise problem?
Will the fix be in a Vray update or do you need to do another recompile of the Bercon maps for 2015?
Forgive me fro cross-posting, but this seems to be a more active thread…
I finding that the Bercon gradient (Vlado’s compiled version BerconMaps_2015_64a) also crashes Max2015 sp3.
Any hope of a fix for this? I’ve got a crash dump to send if needed.
Thanks Jeff for keeping it active…:¬)
I suspect Vlado is busy fixing other VRay related stuff…can’t hurt to keep asking though.
