when scaling bercon noise very small, it tends to filter the noise pretty aggressively at glancing angles.
Hi @ronald_a ,
That’s caused by the “UV Derivatives Scale” on your object/world position uv node. Lower the value dawn a bit and you’ll be able to fix that.
Best,
David.
oh wow, never seen this. just out of interest: are there any other use-cases for this parameter?
Not that I know of, small noises was the only I think. Maybe one of the devs or QA know more.
Best,
David.
Thanks for the info, very good to know!
