Bercon Noise + GGX = Instant Crash
Hi. I´m having this problem long time ago. I re install everything but still the same.
I´m using MAX 2014 and Vray 3.1. If i use bercon whit Blind/Ward/Pong it works perfect, but if i switch to GGX MAX crash instantly. I don´t have problems in Corona, just Vray 3.1 + GGX
I know this issue could not be related to Vray but maybe you can help me to solve it.
Thanks. Bye.
Where exactly in your material do you use the bercon map? Also do you use the random parameters of the bercon map?
Hi Vizioen, thanks for your time.
I generally use it in Bump map, standard parameters, just change size and sometimes distortion. But i can make a bercon noise and change it (whitout connect it to VrayMtl), connect to vraymtl bump map and if i don´t change anything it works fine, i must disconnect/reconnect the map every time i need to change something but is annoying, if i change anything wile bercon is connected to VrayMtl MAX crash.
Hope you can help me. Best regards.
What version of berconmaps are you using?
Maybe try this one.
BerconMaps_2013_64_Vlado.zip (121 KB)
Hi. I feel like an idiot right now. The version you attach works perfect, xD.
I re-install it several times using the one from bercon map site.
Once again thx for your time :wink:
Well there seems to be a problem with the original version. Vlado fixed a few things that made Max crash with the Variance settings, not sure if it has something to do with your problems but I’m glad it’s fixed all the same. You’re welcome.
