berconmap in bump does not work
Hey guys
I am using berconmap and it is not working for the bump. I turn it on the bump channel and does not work. Has anyone been through this problem? I’m using a daily build 1.4 11/04 date. Thank you in advance for suggestions.
Which exactly bercon map you’re using as a bump?
There was a similar discussion some time ago about berconmaps and bump. You may want to check it and see if you’ll find something useful: Corona bump or displacement with bercon tiles - Corona for 3ds Max :: Help Required - Chaos Forum
its bercon tile
I never managed to get decent results with bercon tile bump but I have since learned to use corona’s displacement a bit better without destroying RAM, that or Corona’s updates made it more efficient, something changed either way.
we scrapped using bercon tiles though and either use bitmaps or floorgen now.
