Okey here is the hopefully final (revised) version of the plugin.
For those who haven’t heard of it before its basically raytraced version of the Blobmesh max has. It doesn’t generate a mesh at all, its raytraced (like VRayFog) on render time. This means its infinitely smooth and has no meshing artifacts. It also scales very well (millions of particles are no problem).
Features and fixes in 1.12
Feature: When using a mesh as a source object and Use Particle Size is checked it takes account soft selection (0..1) multiplied by Radius
Bug fix: Using a mesh as a source object with motion blur on doesn’t crash any more
Features and fixes in 1.11:
Feature: Added some new optimizations to make things slightly faster, most noticable on high (over one million) particle counts
Feature: Simple particle systems are supported again (with motion blur and all)
Bug fix: Texture in Multiply mode now supports Strength values above 1.0
Bug fix: When “Use Particle Size” is on, the Leaf Size is ignored, there is no point using it with varying particle sizes
Any bugs/feature requests can be reported here or directly to my email (jerry.ylilammi@gmail.com).
There aren’t any known bugs.
To vlado/VRay developers/Random coders: What would it take to convert this plugin to VRay Maya? I don’t have Maya myself so obviously I can’t do it personally. I guess the VRay interface is pretty much the same so it shouldn’t be a big problem for somebody to compile it for Maya.
The rendering part is very similar; the only difference would be the integration with Maya and reading the particle info from there. I can get one of the guys here to look into it.
I’m using Max 9-32 and “BerconMetaball_9-2008_32.dlo” doesn’t want to load for me. I get an error. Yes, I did put it in the plugins/vrayplugins folder.
! <D:\Programfiles\Autodesk\3ds Max 9\plugins\vrayplugins\BerconMetaball_9-2008_32.dlo> failed to initialize.
Error code 14001 - This application failed to start because the application configuration is incorrect. Reinstalling the application may fix this problem.
Same problem:
Tried the c++ Redistributable Package mentioned above, makes no difference.
A lot of people have reported problems with the 1.11 version so I tested all different flavors (9, 2008, 2009, 2010, 32/64) of the plugin and they work fine on my computer.
If you are certain you’ve done all above then I’m really glueless what could be wrong. I haven’t changed any compiler settings I’m aware of compared to previous builds.
I was getting this problem too. It was because I was missing the latest VC CRT. The ones Bercon linked to earlier in this thread are now actually out of date. You can download the latest here:
Because I didn’t feel like starting a new thread for this here is the new 1.12 version:
1.12
- Feature: When using a mesh as a source object and Use Particle Size is checked it takes account soft selection (0..1) multiplied by Radius
- Bug fix: Using a mesh as a source object with motion blur on doesn’t crash any more
I was reading about the solution to the motion blur problem in a different thread and it prompted me to do this silly little test animation. Thought I’d share it though it is pretty pointless.
