BerconMetaBalls and Vray 2.0 beta
It seems that BerconMetaBalls (v1.14) does not work with Vray 2.0 beta…
I get this message:
error: UNHANDLED EXCEPTION: Preparing ray server Last marker is at ./src/vrayrenderer.cpp.line 2117: Preparing ray server
It will have to be recompiled for V-Ray 2.0 as the V-Ray SDK has changed and is not compatible with the V-Ray 1.5 SDK. Will see what can be done about this.
It would be great to have this. In fact, it wouldn’t hurt for Chaos to do a deal with Jerry and have it packaged with Vray - it’s not something many renderers have and it is hugely useful.
On another note, any news about Phoenix compatibility? My Phoenix is forciebly retired at the moment.
B
In fact, there were some talks in that regard, but we didn’t reach a final agreement. BerconMetaballs is open source now, so ideally anyone can get it.
On another note, any news about Phoenix compatibility? My Phoenix is forciebly retired at the moment.We do have Phoenix builds internally for V-Ray 2.0, will see what can be done about it.
+1 for official chaosgroup berconballs
+1 for sure. Especially if it works with mo-blur :slight_smile:
b
+1
Implementation of berconmetaballs and berconmaps would be a smart move, makes it easier to manage render nodes and manage of plugins.
And don’t forget BerconMetaBallTexture!
Here you go, the latest source codes: http://www.ylilammi.com/BerconMetaball/BerconMetaball\_2010\_11\_22.7z
EDIT: The compilled plugins in the zip above are for 1.5. Somebody has to compile the plugin for 2.0 using the source codes included.
You just need vray sdk and max sdk to compile. I don’t know if there are any major sdk changes in vray 2.0 which would require modifications to the sources.
- Jerry
vlado, or anyone else that knows how to, would you mind compiling jerrys latest berconmetaballs build for vray 2.0 ?
Yep, will try to do that a bit later.
…and maybe ask Mackevision and Dimo very nicely for VrayISO source so you can recompile that too? :wink:
+1 for all the recompiles.
