Is it better to use DR/BB for an animation sequence, or just BB? If just BB is used, I assume BB server needs to be running on each node when the job is submitted to the network? Also, DR is turned off?
Thanks in advance!
Thanks in advance!
I guess I should be so hasty to post a question! Turning on BB Server on all nodes and submitting the job to one of them was WAY quicker with the animation sequence. Each node rendered an entire frame. Definitely the way to go with simple animation sequences! More complex scenes, I’m not so sure.
