Best Practices for Clouds
VRay is release hotfix.
Is that one not compatible?
Yeah, I noticed that. Even with the triangle preview and the bounding box displayed it still gets slow.
This is awesome! I will give it a shot.
Sorry for all the individual replies…
Just went through the history of the V-Ray stable and also verified it with a test with a fire and tapwater toolbar presets - the latest official and stable V-Ray should be missing only the latest AUR version which concerns only particles. This means that the VolumeGrid would load voxels but will not be able to load particles, but it’s not supposed to load particles because it’s a volume GRID anyway.
So I haven’t been able to actually break it. Can you share a cache which is not working in the latest official V-Ray 5?
Thanks!
Let me give it another go to be sure, but once I find one I will post it for you and send a link to support, referencing this thread.
Is there some method to get shadows cast ON TO smoke from other objects to be less opaque? I can use two lights, one without a shadow, but this will of course be slower. Just didn’t know if there was some shadow density I am missing.
Thanks.
Joe are you making the clouds in phoenix from scratch out of interest?
Yes. We simulated a bunch of random clouds of different types, and then picked a few and cloned them. Of course most of the clouds are not meant to be clouds in the sky. You the viewer are meant to standing on a cloud see off to the distance.
@Svetlin.Nikolov the new nightly is a big improvement on viewport speed. Still not fast with a ton of simulator grids, but much better than it was, thanks.
It would be really nice if we could get better hit detection for selecting the volumes. Like if clicking on the closest little preview triangle would select the volume right under the mouse.
In other words, say you have four overlapping volumes in the triangle preview mode… it is hard to select the one you want. The bounding boxes can help if you only have a few, but they become quickly a jumbled mess with many volumes. I’d love to have the selection preview highlight, and the selection itself, be made by clicking on the actual smoke triangle preview. Basically, like selecting any other objects in Max.
To that end maybe there is a way to let the user set a viewport level of detail for the mesh mode preview. Kind of like turbo smooth with a separate viewport and render setting. Max seems pretty fast with actual meshes, especially if we could have them display much lower resolution.
Thanks for all the help.
ugh yess, making these selectable will make stuff even slower… gotta think about a way to make it happen.
The LOD for the Mesh is a hot topic already, adding another vote to it :slight_smile:
What if each grid (Phoenix or VolumeGrid) had an icon like a PHX Source has, we could roll over that icon and get a preview highlight of the triangle preview? So the hit detection could just be on the icon, but the user feedback would be seen as a highlight of the triangle preview (in the camera view).
I am just looking for some way to find a particular grid mesh (from a bunch of overlapping grids) in the camera view. It is not a big deal to roll over other icons to find them. Right now I have to turn them off and on, which is kinda a pain.
I figured hit detection on that triangle preview would be pretty slow. Honestly, for what you are dealing with data-wise the triangle preview is already pretty impressive. Another thought is what about some sort of Convex Hull (which are generally relatively fast to compute) to be used for hit detection, or even for preview.
There is no way to do that I’m afraid. Using two lights is the way to go.
Thanks for the reply. Please ad a vote for a “Shadow Density” control for VRay in general. Most renderers have had this setting for decades. I am surprised VRay doesn’t have one. I get it’s not physically accurate, but it is very helpful.
It’s already logged in the system - adding one more vote for it :slight_smile:
Hey, my colleague Kaloyan did some changes and they are already in the nightlies:
Now the cache converter has an option -exportchannels, after which you can list the channels you want to keep in the cache after conversion. If this option is not mentioned, all channels go into the cache. The syntax is like this:
cache_converter.exe -srcfile ND2_PhoenixFDFire001_####.aur -dstfile outFile_####.vdb -start 0 -end 10 -storagequality 14 -exportchannels Smoke_phx VelocityXYZ_phx -silent
The channel names in AUR caches are:
-Temperature_phx
-Smoke_phx
-Speed_phx
-VelocityX_phx
-VelocityY_phx
-VelocityZ_phx
-ColorR_phx
-ColorG_phx
-ColorB_phx
-Fuel_phx
-WaveletEnergy_phx
-AdvectionOriginX_phx
-AdvectionOriginY_phx
-AdvectionOriginZ_phx
-WaveletU_phx
-WaveletV_phx
-WaveletW_phx
-Viscosity_phx
-TexU_phx
-TexV_phx
-TexW_phx
… and you can also use these aliases for the 3 components of vector channels:
-VelocityXYZ_phx
-ColorRGB_phx
- AdvectionOriginXYZ_phx
- WaveletUVW_phx
- TexUVW_phx
Cheers :slight_smile:
Man you guys are awesome! Thanks.
Oh, what about my question about loading and memory…
Are all channels loaded at the start of a frame, or does it only load the channels as needed? So if I am not referencing temperature will it still load temperature, for instance? You ever experiment with memory mapping the grid data? Would likely work better on linux, though.
Ah, here it is :slight_smile: Best Practices for Clouds - General - Chaos Forum
Thanks. I completely missed that.
Paul Oblomov did some tests with memory mapping, but it wasn’t a big hit, and it shouldn’t be - we still have a couple of particle compression/decompression algorithms that we can optimize, so we do have things to improve in software before we resort to hardware…
One more…
Is there any way to decimate a grid? Like perhaps to take it to half its resolution to speed loading, and displacing, and RAM usage?
I have an existing cloud that was simmed pretty big, would like to use it smaller. Any thoughts? Somehow emit from the hi-res Grid into a low res grid?
Would a decimate option even be possible with the command line converter? Or would that be technically difficult? I was thinking just 1/2, 1/4, 1/8, etc. rather than any interpolation.
Also, it doesn’t seem like the cutter geometry speeds up displacement. I was hoping that the unused cells would be trimmed first and only the visible cells would be displaced (for speed, since the displacement is so slow in Surface mode).
Any way to cut/trim a grid? Even being able to trim that to a different sized cube aligned with the grid would be very useful.
