Best render settings for gaussian splats
Hello everyone,
I have made several gaussian splats that I want to render with VRAY. During the GPU tests I noticed that he needs to load the scene and the splats every new frame. This increase the overall render time. Would it be possible to calculate the scene and splats one time and then only render the frames? It would be great if someone could help me with settings that improve rendering speed.
There’s no way to do that, but I’ll ask the devs if it can be done. As for rendering speed, there are no specific settings concerning GS, particularly - it comes down to the samples/noise limit.
EDIT: Discussed this with the product manager - an improvement is planned. I’ve logged it as (internal tracker ID: VGPU-6905).
Thank you so much for your reply! I am really looking forward to the GS improvements.
A couple of other questions regarding gaussian splats. I like to add a velocity render element so that I can add the camera velocity later in post. But it seems like that the render output is grey when rendering with gaussian splats. Is this correct? Or maybe I am doing something wrong. Also I like to create a fixed ZDepth for the Gaussian Splats. Meaning that if the camera animates through the scene the ZDepth will not shift. Hopefully you can help me with a solution.
Neither the VRayVelocity nor the VRayZDepth element is yet supported for Gaussian Splats. The latter will be soon, though. Will make a note about velocity, too. I’m curious - are you animating the Splat itself?
Thank you for your reply. That is weird, the ZDepth render element works for me. If I add this to the render elements, it renders the camera ZDepth perfectly. I was wondering if I can make this ZDepth static. I presume this needs to be done using a texture map? Velocity support would be amazing. This way we can render even faster.
At this moment all my splats are static. But I have one last question, I really like the option to cull the splat using a distance map. It works perfectly. Unfortunately you dont see the result in the viewport. Is this correct?
Pardon, I wasn’t aware it got implemented in Update 2:
“Add a VRayGaussianSplats render element to hold the shading results from VRayGaussiansGeom, and support for z-depth”
Not sure if you can make it static, since it depends on the camera distance from the objects.
So you need the velocity element to later produce the camera motion blur?
Yes, that’s correct.
Yes, you are correct regarding the velocity use. Gaussian Splatting is already fast to render but I always looking for ways to render even faster. Adding a velocity pass to use later in comp would be great. It would also be great if I could see the cull from the distance texture in the viewport. This way I can take parts out of several splats and combine them.
Best you add your ideas in the Portal.
Thanks for the feedback!
We have an improvement for this, ready for testing. It should drastically improve the loading time for GS on GPU. Please let me know if you are interested to test this improvement, if yes I will send you a build.
Best,
Muhammed
That is amazing! Thank you for the invite. For now I am using the CPU version of Vray for rendering Gaussian Splats. The plan is to use many Gaussian Splats and that will result in excessive use of VRAM.
This should work now in the latest hotfix 2 build.
That is great news! Does this also work for CPU rendering?
Answered you here.
