best setting for animation whit moving people (3dsmax populate)
Hello corona users. Can someone pls give me advice for best setting if I wonna do animation whit moving people? I allready finish 100 frames whit precomputated UHD cache for every 50th frame. But I still get flickering in reflection.
Shold I use some diferent settings? Thank You.
If it is an exterior animation, you could try switching to pt+pt. This is the safest solution.
Calculating one uhd cache for each frame with the animation preset enabled should work fine as well.
Last possibility is to save the cache each nth frame (as you did), and then use the load+append option to calculate the cache only where it is needed.
More info: https://coronarenderer.freshdesk.com/support/solutions/articles/5000515648
