the Distributed render is great, but i’d like to be able to see in once all the rendernodes.
Let me show you : (see attached picture)
You have way too many nodes
When seeing all this together, is it important for you to see all the details of all nodes? I’m thinking that it might be better to be able to collapse the node entries, so they’ll still be displayed in a single column, but each entry will take less vertical space. If we were to implement this, what is the most important info for you that should be visible even in the collapsed state?
Maybe just the params without name :
xx - yy - gb/GB
for update : xx - passes : yy - ram used gb/GB
And keep the green / red name to see in once where are the errors if any.
