I have some Vray Light objects that I want to isolate so I can apply a glow to them in After Effects. I set the Vray Lights Object ID to 2, but the Multimatte render element is not picking them up? (Bummer.)
So, what is the best way to create a matte for Vray Lights?
Is this a really dumb question or something? Either people aren’t answering because I’m an idiot and the answer’s too obvious -- or maybe it’s the opposite, and the answer isn’t easy -- or doesn’t exist.
I feel like I know Vray fairly well, but admittedly not an expert on the massive number of Render Elements at our disposal). I would think this is something that people commonly need to do. I know I can do a custom pass with matte objects and all that -- but I was hoping for a render element that I can add to the beauty pass for simplicity/speed’s sake.
I don’t think that’s a good option. I believe I read Vraylight Material is much slower to render than a normal Vraylight since the native light object is heavily optimized. Maybe that’s outdated info, but I don’t think so.
in this situation, that is not the case. you are still using the light to iluminate the scene; the vraylight material is just to emulate the shape of the light so you can mask it.
Okay, that make sense. Thanks. The issue is that as the lights are far away, and using a Vraylight for the renderable shape works just fine. I’ll now have to create a bunch of planes for each lights in order to use this other method. I wish there was a way to just use the VrayLight objects as they are.
(Vlado: -- is it possible to get VrayLights to work with Obj ID in Multimatte?.. I don’t mean in the current Vray version but is it ‘technically’ possible as a future enhancement?)
Yes, switch VRayObjectID output type to Color (with AA). Compared to a MultiMatte - the quality of the matte you can extract is reduced if objects appear in very similar colors of course.
You can also use psd-manager - just tested. Use the scene layer output (e.g. you may have your lights on a layer anyway) or named selection set output mode then.
It is kind of unusual for a light to appear as geometry in the render - that is why some tools behave a bit strange (like not being able to be pick it in the include/exclude list of a MultiMatte, same problem in psd-manager object output list). It is a special case that needs to be handled differently in the code.
