Best way to use Enscape plants in Vectorworks
Does anyone have experience with using Enscape plants/vegetation models in Vectorworks? Is there a preferred workflow for attaching an Enscape asset to the ‘3D geometry’ for a symbol within Vectorworks?
I’d love to have it so that I could select a plant in VW and the Enscape 3D asset is already attached, rather than having to plot all the plants again within Enscape itself.
Ideally, the Enscape asset would also be able to be resized (height/width) depending on the dimensions of the plant data within Vectorworks.
Hope that makes sense. Appreciate any help/guidance!
While this is not yet directly implemented, we have a standing feature request about such workflows which we are looking into. Thank you for bringing this request to our attention as well.
In the meantime, you should be able to use the “Referenced Design Layers” feature in Vectorworks to achieve an improved workflow like this:
  • Place your primary plants or symbol geometry on a dedicated design layer in your master Vectorworks file (or a separate file).
  • Plot your Enscape 3D assets once over those symbols on that same layer.
  • Use Vectorworks’ native Design Layer Referencing to link that layer into any other project file.
This way, you would basically have one “master file” to rely on and link to in which the plotting and size adjustments have already been perfomed.
We have been made aware that under certain circumstances, an asset from a referenced file might disappear in Enscape. Restarting Enscape or slightly shifting the referenced symbol should trigger a full re-export and force them to show up again.
I hope this information is helpful to your workflow while we consider and work on the feature request.
