Hello all, We are trying to use Enscape for Rhino in a walkthrough in VR in a model that is already very heavy. We can get it to work at this level, but when we want to add RPC’s for our entourage and trees and people enscape for rhino does not seem to read them, and it renders their mesh geometry as generic. I understand that Enscape for rhino does not read Proxies or VRay proxies, so I am asking if there is a workaround to keep the model light, but work with Enscape in a VR walkthrough. If anyone has any insight or tips on how to achieve this It would be most appreciate. Thanks in advance, Bernard
With very large model converting to meshes and then joining into multiple into single meshes per material, dramatically reduces the file size in rhino and makes it feel a lot lighter, I dont know but I would guess this would also “speed” up enscape, as the render will be converting to meshes somewhere along the pipe line anyway. The down side is that the nice edibility of the models are lost, so i usually just mesh the bits I know wont change and keep all the changing bit as rhino solids.
“QuadrangulateMesh” in rhino is a good one for making boxy meshes look nicer/ easier to edit points
“ReduceMesh” is also a good way to keep vegetation to a few thousand triangles.
T
