Could we have a slightly better automatic naming of our render elements?
Currently, we have Mask01, Mask02, etc. The problem with this is that with animation if the elements aren’t manually renamed, you end up with Mask01001, Mask01002, Mask02001, Mask02002 etc. which causes a load of problems and time spent using renaming software to fix the problem.
Adding an underscore at the end of each element would fix this issue, or using alphabetical increments.
